Can't install Let's Encrypt certificate for a domain/Plesk panel
Detail: Fetching http://example.com/.well-known/acme-challenge/do75fK79n_uF9JimlezVpQQQfmvHaOVd7T8cjZKVvWk: Timeout during connect (likely firewall problem)
Error: Could not issue a Let's Encrypt SSL/TLS certificate for example.com. Authorization for the domain failed.
Invalid response from https://acme-v01.api.letsencrypt.org/acme/authz/dlJ9iUsYRM51xlzLkS8KpRJYccRh1yKRUJEPgLMoRFc.
Type: urn:acme:error:connection
Status: 400
Details: Fetching https://example.com:8443/.well-known/acme-challenge/44DVtYx2WBKaujKCYO7tOxZ4nS2-m_-Ci5dLoQw0X34 Error getting validation dataAn SSL / TLS certificate could not be issued for example.com
The SSL / TLS Let's Encrypt certificate could not be issued for example.com. Authorization error for the domain.
Invalid response from https://acme-v02.api.letsencrypt.org/acme/authz-v3/xxxxxx.
Type: urn: ietf: params: acme: error: connection
Status: 400
Detail: Fetching http://example.com/.well-known/acme-challenge/DOgtM-HLdDLxfaGej39Fip168f6njHhwot47XuyGANo: Error getting validation data -
The domain resolves to the correct Plesk server IP address
Opening the site in a browser displays the error
This site can’t be reached
ERR_CONNECTION_TIMED_OUT
Ports 80/443 are filtered by a firewall
# nmap -Pn -p80,443 example.com
PORT STATE SERVICE
80/tcp filtered http
443/tcp filtered http
Open the web ports 80 and 443 on the firewall.
Note: If the issue persists, contact the ISP, hosting provider, or network administrator for assistance locating and opening the block.
- To automatically configure the internal firewall to allow all necessary connections, use Plesk Firewall. Additional software (like Imunify360) must also be configured according to its documentation.
- For external firewalls, follow the appropriate guide (contact the hosting provider if not listed): Amazon EC2, Lightsail, Google Cloud, Azure, Alibaba Cloud.
