Is it possible to configure multi-factor authentication (MFA) to access Plesk?
4 comments
    Nikolay K
    How to change 16 symbol secret key for google authenticator to a new one?
    After disabling plugin and reenabling it, key is the same.
    Just in case when device with otp generator was lost, compromised or whatever
    1
    eCom Seller
    It's pretty crazy that in 2024 Plesk still can't do enforced 2fa, AND can't even do any 2fa on sub accounts (webmaster, etc.).
    1
    Jay Dubinsky
    The extension is not called MFA anymore in plesk. If you're looking like a maniac clicking around, install the Google Authenticator extension.
    Thomas Schleicher
    not “learnMoreURL” but “learnMoreUrl” - difference small / caps matters…
