How to block or whitelist specific countries through Plesk?
16 comments
    Unknown User
    please update it
    Plesk Obsidian 18.0.52
    Stefan Yakubov
    Hello,
    Thanks, the article is updated.
    Daniel Vengoechea
    For anyone looking this is the complete security rule with all countries except US and CO
    SecGeoLookupDB /usr/share/GeoIP/GeoLiteCountry.dat
    SecRule REMOTE_ADDR "@geoLookup" "phase:1,chain,id:99999932392,drop,log,msg:'Blocking %{geo.country_code}'"
    SecRule GEO:COUNTRY_CODE "@pm AD AE AF AG AI AL AM AO AQ AR AS AT AU AW AX AZ BA BB BD BE BF BG BH BI BJ BL BM BN BO BQ BR BS BT BV BW BY BZ CA CC CD CF CG CH CI CK CL CM CN CR CU CV CW CX CY CZ DE DJ DK DM DO DZ EC EE EG EH ER ES ET FI FJ FK FM FO FR GA GB GD GE GF GG GH GI GL GM GN GP GQ GR GS GT GU GW GY HK HM HN HR HT HU ID IE IL IM IN IO IQ IR IS IT JE JM JO JP KE KG KH KI KM KN KP KR KW KY KZ LA LB LC LI LK LR LS LT LU LV LY MA MC MD ME MF MG MH MK ML MM MN MO MP MQ MR MS MT MU MV MW MX MY MZ NA NC NE NF NG NI NL NO NP NR NU NZ OM PA PE PF PG PH PK PL PM PN PR PS PT PW PY QA RE RO RS RU RW SA SB SC SD SE SG SH SI SJ SK SL SM SN SO SR SS ST SV SX SY SZ TC TD TF TG TH TJ TK TL TM TN TO TR TT TV TW TZ UA UG UM USs UY UZ VA VC VE VG VI VN VU WF WS YE YT ZA ZM ZW "
    1
    Fadi Asbih
    Is there also a way to block a specific ISP, IP to ISP.
    i.e. block DigitalOcean, LLC
    Stefan Yakubov
    Hello, Fadi Asbih
    Yes, you can find the list of DO subnets here:
    https://docs.digitalocean.com/products/platform/
    Bragi Austfjörð (Edited )
    Yeah this is not working.
    After I have blocked countries like Bulgaria and Latvia, still manage to try to hack my server and the countries ip still shows up in IP Address Banning (Fail2Ban)
    Hope for the best :)
    -1
    Daniel Vengoechea
    @bragi you should try workaround 2. It does work , test it with a vpn . I confirm it does work
    Bragi Austfjörð
    @Daniel Vengoechea
    Method II dos not work and is uselesss.
    This method is useless I'm running the latest Plesk panel and this dos not work at all just like opening a new port in firewall for SSH that doesn't work either.
    Bragi Austfjörð
    And I'm paying money for this panel that can't even open a new port nor block country with country code
    Bragi Austfjörð
    I'm forced to block every IP that is trying to hack my server using the firewall.
    Stefan Yakubov
    Bragi Austfjörð in case you require clarifications on how to use that or have some additional questions regarding behavior in your environment -  you can contact technical support.
    Bragi Austfjörð
    @Stefan Yakubov
    I found out why blocking countries and opening custom port did not work it was do to my server has FirewallD running, after disabling firewallD everything started to work.
    1
    Bragi Austfjörð
    I found out that opening port via plesk firewall interface will not open port in firewallD. Just follow this and you will be all set. https://www.digitalocean.com/community/tutorials/how-to-set-up-a-firewall-using-firewalld-on-centos-7
    n2linux acens
    WORKAROUND II
    https://dl.miyuru.lk/geoip/dbip/country/dbip4.dat.gz
    This URL is down
    Martin Pineault
    @Daniel Vengoechea
    Do you have your "...complete security rule with all countries except US and CO..." in JSON format so I can Import it directly in Plesk after fine-tuning it?
    Thank you,
    Manuel Hanen
    If your lifetime is limited, create just ONE Geoblock-Country and EXPORT, EDIT, then IMPORT your Fireall rules als json.
    Here is my "DE"-Only allowed rule.
            "action": "deny",
            "class": "custom",
            "direction": "input",
            "from": "AD,AE,AF,AG,AI,AL,AM,AO,AQ,AR,AS,AT,AU,AW,AX,AZ,BA,BB,BD,BE,BF,BG,BH,BI,BJ,BL,BM,BN,BO,BQ,BR,BS,BT,BV,BW,BY,BZ,CA,CC,CD,CF,CG,CH,CI,CK,CL,CM,CN,CO,CR,CU,CV,CW,CX,CY,CZ,DJ,DK,DM,DO,DZ,EC,EE,EG,EH,ER,ES,ET,FI,FJ,FK,FM,FO,FR,GA,GB,GD,GE,GF,GG,GH,GI,GL,GM,GN,GP,GQ,GR,GS,GT,GU,GW,GY,HK,HM,HN,HR,HT,HU,ID,IE,IL,IM,IN,IO,IQ,IR,IS,IT,JE,JM,JO,JP,KE,KG,KH,KI,KM,KN,KP,KR,KW,KY,KZ,LA,LB,LC,LI,LK,LR,LS,LT,LU,LV,LY,MA,MC,MD,ME,MF,MG,MH,MK,ML,MM,MN,MO,MP,MQ,MR,MS,MT,MU,MV,MW,MX,MY,MZ,NA,NC,NE,NF,NG,NI,NL,NO,NP,NR,NU,NZ,OM,PA,PE,PF,PG,PH,PK,PL,PM,PN,PR,PS,PT,PW,PY,QA,RE,RO,RS,RU,RW,SA,SB,SC,SD,SE,SG,SH,SI,SJ,SK,SL,SM,SN,SO,SR,SS,ST,SV,SX,SY,SZ,TC,TD,TF,TG,TH,TJ,TK,TL,TM,TN,TO,TR,TT,TV,TW,TZ,UA,UG,UM,US,UY,UZ,VA,VC,VE,VG,VI,VN,VU,WF,WS,YE,YT,ZA,ZM,ZW",
            "id": 114,
            "name": "Geoblock",
            "ports": "",
            "type": "custom"
    1
