kb: how-to
Plesk for Linux
ABT: Group A
How to enable Nginx caching in Plesk?
Note: This feature is available starting from Plesk 17.8 version.
Note: Before enabling caching, it is strongly recommended to switch PHP files processing to PHP-FPM application served by nginx type in Domains > example.com > PHP settings.
To enable nginx Byte-Cache and nginx FastCGI caching, follow these steps:
Enable nginx caching for single domain
- Log into Plesk
- Go to Domains > example.com > Apache & nginx Settings
- Tick the Enable nginx caching option and press the OK button to apply the changes:
Enable nginx caching for all domains using a service plan
- Log into Plesk
- Go to Service Plans > Hosting Plans tab
- Click on the name of the existing plan to edit it.
- Go to the Web Server > nginx settings and enable checkbox next to Enable nginx caching:
- Click Update & Sync
