Plesk for Windows
Plesk for Linux
kb: technical
- Plesk for Windows
Plesk update fails or Plesk panel cannot be accessed with the following message:
PLESK_ERROR: PHP Fatal error: Class Laminas\ServiceManager\ServiceLocatorInterface cannot implement previously implemented interface Psr\Container\ContainerInterface in /opt/psa/admin/plib/modules/monitoring/vendor/laminas/laminas-servicemanager/src/ServiceLocatorInterface.php on line 18
The outdated version of the Monitoring extension is installed on the server.
1 comment
[panel] Retrieving Extensions Catalog feed: https://ext.plesk.com/api/v4/packages?platform=unix&with-hidden&with-unstable
[panel] Execute: '/usr/local/psa/admin/bin/send-error-report'
Failed connect to ext.plesk.com:443; No route to host
