Starting on October 19, 2021, we will enable single-sign-on for our Plesk Support Center to provide a seamless login/account experience. This implies that you’ll be able to use a single account across any of our web-facing properties.
To be prepared for this change and to avoid the need to register during your next ticket submission after the change, we encourage you to create an account here before October 19 using the same email address as your current Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account. You will continue to use ZenDesk authentication until we switch over to single-sign-on on October 19th.
Where does Let's Encrypt extension keep .pem files for private and public keys on a file system?
5 comments
    Heinrich Krebs
    This information seems outdated in PLESK Obsidian.
    The paths aren't present anymore.
    Ivan Postnikov
    Hello,
    These paths for Plesk Obsidian remained the same.
    This was checked on a test environment with a live domain with Let's Encrypt certificate:
    # plesk -v
    Product version: Plesk Obsidian 18.0.23.1
    OS version: CentOS 7.7.1908 x86_64
    # ls /usr/local/psa/var/modules/letsencrypt/etc/archive/example.com/
    cert1.pem cert3.pem chain2.pem fullchain1.pem fullchain3.pem privkey2.pem
    cert2.pem chain1.pem chain3.pem fullchain2.pem privkey1.pem privkey3.pem
    Eduardo
    I do not find the files. What is the archive? ther is no folder archive
    Eduardo
    [root@server letsencrypt]# ls -alltotal
    total 56
    drwxr-xr-x. 6 psaadm 4096 Jun 19 13:08 .
    -rw-------. 1 psaadm 28672 Jun 19 13:08 letsencrypt.sqlite3
    drwx------. 2 psaadm 4096 Jun 19 11:59 registrations
    drwxr-xr-x. 28 psaadm 4096 Jun 18 04:30 ..
    drwxr-xr-x 3 psaadm 4096 Jun 17 03:34 venv
    -rw-r--r--. 1 psaadm 0 Jun 17 03:34 .keep
    -rw-r--r--. 1 psaadm 898 Jun 17 03:34 vendor.json
    drwx------ 2 psaadm 4096 Jun 16 08:08 tmp
    drwx------. 2 psaadm 4096 Jun 16 07:50 orders
    Alexey Lapshin
    Hello @Eduardo
    I would like to inform you that directories: `/usr/local/psa/var/modules/letsencrypt/etc/archive/` as well as `/usr/local/psa/var/modules/letsencrypt/etc/live/` appear in /usr/local/psa/var/modules/letsencrypt/ when the first Let's Encrypt certificate issued.
    If you have issued certificate using Let's Encrypt extension, however no directories there - submit a ticket to us for further investigation: https://support.plesk.com/hc/en-us/articles/213608509-How-to-submit-a-request-to-Plesk-support-
