Plesk for Windows
Plesk for Linux
kb: how-to
ext: le
ABT: Group B
- Plesk for Windows
Where do Let's Encrypt and SSL It! extensions keep .pem
files for private and public keys of Let's Encrypt certificates on a file system?
On Linux systems, the .pem
files are located in these directories:
For Let's Encrypt extension - /usr/local/psa/var/modules/letsencrypt/etc/archive/example.com/
For SSL It! extension - /usr/local/psa/var/modules/sslit/etc/archive/example.com/
On Windows systems, the .pem
For Let's Encrypt extension - %plesk_dir%var\modules\letsencrypt\etc\archive\example.com\
For SSL It! extension - %plesk_dir%var\modules\sslit\etc\archive\example.com\
5 comments
This information seems outdated in PLESK Obsidian.
The paths aren't present anymore.
Hello,
These paths for Plesk Obsidian remained the same.
This was checked on a test environment with a live domain with Let's Encrypt certificate:
# plesk -v
Product version: Plesk Obsidian 18.0.23.1
OS version: CentOS 7.7.1908 x86_64
# ls /usr/local/psa/var/modules/letsencrypt/etc/archive/example.com/
cert1.pem cert3.pem chain2.pem fullchain1.pem fullchain3.pem privkey2.pem
cert2.pem chain1.pem chain3.pem fullchain2.pem privkey1.pem privkey3.pem
I do not find the files. What is the archive? ther is no folder archive
[root@server letsencrypt]# ls -alltotal
total 56
drwxr-xr-x. 6 psaadm 4096 Jun 19 13:08 .
-rw-------. 1 psaadm 28672 Jun 19 13:08 letsencrypt.sqlite3
drwx------. 2 psaadm 4096 Jun 19 11:59 registrations
drwxr-xr-x. 28 psaadm 4096 Jun 18 04:30 ..
drwxr-xr-x 3 psaadm 4096 Jun 17 03:34 venv
-rw-r--r--. 1 psaadm 0 Jun 17 03:34 .keep
-rw-r--r--. 1 psaadm 898 Jun 17 03:34 vendor.json
drwx------ 2 psaadm 4096 Jun 16 08:08 tmp
drwx------. 2 psaadm 4096 Jun 16 07:50 orders
Hello @Eduardo
I would like to inform you that directories: `/usr/local/psa/var/modules/letsencrypt/etc/archive/` as well as `/usr/local/psa/var/modules/letsencrypt/etc/live/` appear in /usr/local/psa/var/modules/letsencrypt/ when the first Let's Encrypt certificate issued.
If you have issued certificate using Let's Encrypt extension, however no directories there - submit a ticket to us for further investigation: https://support.plesk.com/hc/en-us/articles/213608509-How-to-submit-a-request-to-Plesk-support-
