If you had already registered your account at Plesk 360 (formerly known as My Plesk) please use one for login. Otherwise please re-register it using the same email address as your existing Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account.
DKIM does not work: This message does not contain a DKIM Signature
1 comment
    Raivo Kaldma
    hi,
    why plesk 18.0.35 Update #1 DKIM signature contains Received?
    DKIM-Signature: ...
                                h=Received:To:Subject:From;
    I read that signature MUST NOT CONTAIN Recived
    (http://dkim.org/specs/rfc4871-dkimbase.html  5.5
    The following header fields SHOULD NOT be included in the signature:
    Return-Path
    Received
    Comments, Keywords
    Bcc, Resent-Bcc
    DKIM-Signature
    Regards,
