Starting on October 19, 2021, we will enable single-sign-on for our Plesk Support Center to provide a seamless login/account experience. This implies that you’ll be able to use a single account across any of our web-facing properties.
To be prepared for this change and to avoid the need to register during your next ticket submission after the change, we encourage you to create an account here before October 19 using the same email address as your current Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account. You will continue to use ZenDesk authentication until we switch over to single-sign-on on October 19th.
How to check what SSL/TLS versions are available for a website on a Plesk server?
2 comments
    Jack Leonard
    I disabled TLS versions 1.0 and 1.1 and put the SSL settings to modern on my plesk server but cdn77.com tls test shows them still enabled. Also the nmap test shows them.
    I run Plesk Obsidian 18.0.27 Update #1 on Centos 7.
    Output of
    ]# cat /etc/sw-cp-server/conf.d/ssl.conf
    ssl_protocols TLSv1.2;
    ssl_ciphers EECDH+AESGCM+AES128:EECDH+AESGCM+AES256:EECDH+CHACHA20:EDH+AESGCM+AES128:EDH+AESGCM+AES256:EDH+CHACHA20:EECDH+SHA256+AES128:EECDH+SHA384+AES256:EDH+SHA256+AES128:EDH+SHA256+AES256:EECDH+SHA1+AES128:EECDH+SHA1+AES256:EDH+SHA1+AES128:EDH+SHA1+AES256:EECDH+HIGH:EDH+HIGH:AESGCM+AES128:AESGCM+AES256:CHACHA20:SHA256+AES128:SHA256+AES256:SHA1+AES128:SHA1+AES256:HIGH:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!3DES:!MD5:!PSK:!KRB5:!aECDH;
    ssl_prefer_server_ciphers on;
    What do I miss?
    Ivan Postnikov
    Hello Jack Leonard
    The displayed configuration is for Plesk Panel itself.
    Use this instruction: https://support.plesk.com/hc/en-us/articles/115000422229
