Email notification is sent from KernelCare: /usr/bin/kcarectl --auto-update --gradual-rollout=auto Unknown Kernel
2 comments
    Alan Melnikov
    Hello, this message comes to me too: Cron <root@static> /usr/bin/kcarectl --auto-update --gradual-rollout=auto, Can you tell me what to do?
    Taras Ermoshin
    Hello @Alan Melnikov !
    Is there the text starting with "Unknown Kernel" after "--gradual-rollout=auto" ? If yes, then this article describes your case and you should follow the instructions from the Resolution section.
    Also, this article from CloudLinux (they develop KernelCare) can help you find out if your kernel is supported or not.
