How to proxy requests from domains to Docker container in Plesk?
2 comments
    Blake Moore
    Im currently using the Litespeed Webserver addon which requires Nginx to be turned off to work. How can i run nginx only for docker proxy without interfering with my litespeed webserver? Or is this impossible?
    Alexandr Redikultsev
    Hi @Blake Moore.
    Nginx can be enabled only server-wide, so in case of Litespeed it is hardly an option. In theory, it should be possible to configure some sort of proxy in Litespeed configuration files manually, however this scenario was not tested and it will be impossible to manage this via Plesk as described in the article.
