Can not switch to LiteSpeed webserver: Nginx reverse proxy server is currently running and must be stopped
2 comments
    TheBlueZombie
    anyone can do kill -9 pid but the problem not is solved, this is a patch, at next reboot the problem is the same and if you working with some people the next worker will have the same problem...
    Alexandr Redikultsev
    Hello @TheBlueZombie.
    The article describes how to resolve the immediate issue indeed. If you have any information regarding the root cause or how exactly to solve it better, do not hesitate to share your thoughts with us!
