Website fails to be opened: ERR_CONNECTION_REFUSED
4 comments
    Andre Freitas
    In my case, the nginx appears to be on.
    I restart nginx = nothing.
    I restart apache = nothing.
    I reboot server, all websites are back on.
    Please help, as I have no clue.
    Ivan Postnikov
    Hello @Andre,
    As I can see, you have already submitted a ticket to us.
    That is the best option for this case as deeper investigation is required.
    absolutepast (Edited )
    Hi @Alexandr,
    Thanks so much for this.
    It seems that Nginx was disabled 'automatically' - ie: my server and sites were running fine, and then all of a sudden overnight, this issue occured. It was resolved by following your solution.
    Is there any reason that this issue could happen 'automatically' - ie: with no config changes done by me?
    Thanks
    Alexandr Redikultsev
    Hi @absolutepast,
    There is no way nginx can be stopped automatically without any failures. I would recommend checking journalctl logs for nginx and /var/log/nginx/error.log file for some error messages and configure automatic restart of ngixn on failure on a systemd level: https://www.freedesktop.org/software/systemd/man/systemd.service.html
