Unable to start Dr.Web antivirus daemon (Plesk Premium Antivirus)
15 comments
    Ivan Postnikov
    Hello @Fossy,
    Thank you for sharing your user experience.
    Glad to hear that another article helped.
    Cross-links will be added to these 2 articles to improve their findability.
    Jan Bludau
    the solution ends with the same error:
    mail:~# service drwebd start
    Starting Dr.Web drwebd...
    Dr.Web (R) daemon for Linux/Plesk Edition v6.0.2.1
    Copyright (c) Igor Daniloff, 1992-2019
    Doctor Web, Moscow, Russia
    Support service: http://support.drweb.com
    To purchase: http://buy.drweb.com
    Key file: /opt/drweb/drweb32.key - Key file was not found! (No such file or directory)
    A path to a valid license key file was not specified.
    Plesk authorization failed: HTTP request error [35]
    Error: Plesk Software not running.
    Jan Bludau
    this solution is working:
    https://support.plesk.com/hc/en-us/articles/115001211585-Premium-Antivirus-service-fails-to-start-Plesk-authorization-failed-HTTP-request-error
    • Add TLSv1 in the ssl_protocols in the /etc/sw-cp-server/conf.d/ssl.conf, e.g:
      ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
    • Restart sw-cp-server and drwebd services:
      # service sw-cp-server restart
    Artyom Baranov
    @Jan Bludau,
    Hi!
    Glad to know that you have found the answer in our Knowledge Base.
    Jan Bludau
    Dank @plesk, dass dies bestehende :-)
    Ich hoffe, ich konnte einige Menschen helfen, die @google suchen und fand diese erste „/opt/drweb/drweb32.key - Key file was not found!“
    Graham Jones
    None of the solutions on this page work. I have exactly the same error messages as described here and on the alternative suggestion linked here. However, nothing works. Completely uninstalling Plesk Antivirus and reinstalling leads to the same errors. I have searched high and low for a solution. Nothing works...! Any ideas...?
    Maxim Krasikov
    Hello @Graham Jones,
    Please contact Plesk support for the deep investigation of the issue:
    Graham Jones
    Hi Maxim
    I have now been able to resolve the issue. I managed to log in via FTP. I then deleted the ssl.conf file, then rebooted the server.
    Upon checking the newly created SSL settings in /etc/sw-cp-server/conf.d/ssl.conf they were exactly the same as the file I deleted. Nothing was different, except it was a new ssl.conf file.
    So, a bit of a mystery, but everything is working OK now.
    Maxim Krasikov
    Glad to know that you have found the solution!
    It may be helpful to other Plesk users.
    Dennis Koehler (Edited )
    service drwebd restart gives me:
    Key file: /opt/drweb/drweb32.key - License key file error!
    Daemon is enabled for protecting 14 e-mail`s:
    But reinstalling didn't solve my problem, I do have a valid license and there are no TLS / SSL problems either? Do I have to switch to Kaspersky now?
    Ivan Postnikov
    Hello @Dennis,
    Could you, please, submit a request to Plesk Technical Support for further investigation: https://support.plesk.com/hc/en-us/requests/new
    You may use Plesk Premium Antivirus license number in the request form.
    Dennis Koehler
    @Ivan: I can't submit any request - I can fill out the form, but there is no button to submit it...
    Ivan Postnikov
    Dennis Koehler
    "Submit" button appears after license number and fields marked with "*" are filled in.
    Adel MHARI (Edited )
    Hello
    Switching the tls version to "Modern" caused this issue.
    Setting back the option to "Intermediate (recommended)" allowed me to restard drweb.
    This occurs under
    • OS: Ubuntu 16.04.6 LTS
    • Product: Plesk Obsidian 18.0.23 Update #4
    I have some other servers under Ubuntu 18 that are not concerned by the issue
    Hope this helps
