How to add a custom skin for Roundcube Webmail in Plesk?
4 comments
    Michel vd Lingen
    Just tried the above with the Elastic skin, as the other Roundcube skins are a pain when you open your webmail with your phone or tablet, however it doesn't work.
    Seems to me it doesn't load any CSS and images, though everything was done correctly...
    Ivan Postnikov
    Hello @Michel,
    For issue with custom skin it is better to contact Elastic developers:
    https://github.com/roundcube/roundcubemail/tree/master/skins/elastic
    To troubleshoot the issue on your own, enable debug using the instruction, reproduce the issue and analyze the obtained log.
    Denis Gomes Franco
    Comments are old but maybe this will help someone out there:
    This *will not* work with the Elastic skin. Elastic is a quite beautiful skin but it has dependencies that are not met with the Roundcube version shipped with Plesk. I believe I read this somewhere in the documentation, it will only work with the latest version of Roundcube. And since that version is RC only at this point, it won't be included in Plesk until it's stable.
    Ivan Postnikov
    Hello @Denis,
    Thank you for the notice.
    It may be useful for other Pleskians.
