- Plesk Onyx for Linux
When clicking the Secure button in Plesk at Domains > example.com > Check Security nothing happens: There is still a red exclamation mark next to Permissions for files and directories.
There are several files or directories inside a domain document root directory that do not belong to the
psacln
group:# find /var/www/vhosts/example.com/httpdocs/* ! -group psacln
drwxr-xr-x. 9 sysuser apache 4096 Aug 11 2016 wp-admin
-rw-r--r--. 1 sysuser apache 4035 Sep 18 2015 wp-trackback.php
Incorrect ownership: all files and directories under a domain document root directory should belong to psacln
group.
Connect to the Plesk server using SSH.
Modify the ownership for all files and directories inside domain's document root:
# chown -R :psacln /var/www/vhosts/example.com/httpdocs/*
If the subdomain is affected:
# chown -R :psacln /var/www/vhosts/example.com/subdom.example.com/*
Set group ownership for httpdocs directory itself to
psaserv
:# chown :psaserv /var/www/vhosts/example.com/httpdocs
# chown :psaserv /var/www/vhosts/example.com/subdom.example.com/
