How to create several mailboxes on a Plesk server at once using a single command or a script?
11 comments
    Myhost.ie Support
    The script returns: -bash: ./createmail.sh: /bin/bash^M: bad interpreter: No such file or directory when obtained from wget
    This is probably caused by MSWin line endings?
    Bato Tsydenov
    @Martin
    Thank you for notice. I have updated the article and now working script is attached.
    Bernardo Murillo Montoya
    Hello,
    I created the file mai.txt with the format: "user@domain password"
    but after in the script i see "insertpasswordhere" means every account will be created with the same passwords.
    After research i executed this script:
    for /F "tokens=1,2 delims= " %i in (c:\mail.txt) do plesk bin mail.exe -c %i -passwd %j -mailbox true
    And now the scripts creates the user with the password from file mail.txt.
    if some password is not complex enought will show you the status.
    Alexandr Redikultsev
    Hello @Bernardo Murillo!
    Thank you very much for the input.
    I have updated the article accordingly.
    Stefano Poggioli (Edited )
    Hello,
    everithing seems to be working properly with no errors but...
    passwords are not taken correctly (I set up the txt file as described).
    In fact, if a user tries to use the email address or enter webmail, the password is not recognized.
    If I re-enter the same passwords in plesk email setup, they become correct.
    Why?
    Nikolai Graf-Rüssel
    Is it possible to bulk upload email aliases?
    Denis Bykov
    @Stefano Poggioli
    In case you do it on Windows, I can assume that 'mail.txt' is not well-formed. Try to use the default notepad.exe or notepad++ to edit the input file.
    On Linux, the same may apply if the graphical document editor is used instead of a simple text editor.
    Denis Bykov
    @Nikolai Graf-Rüssel
    Unless I am missing something, the article addresses exactly it.
    Could you clarify your use-case in more detail?
    Nikolai Graf-Rüssel
    This is just for whole mailboxes.
    I just want to add to a mailbox more aliases. Can I do that via bulk with a single script?
    Anton Maslov
    Hi Nikolay,
    Please check documentation and use the same approach combining "for" and command line to do scripts:
    For details on using these options, check the documentation articles: for Linux and for Windows.
    1
    Nikolai Graf-Rüssel
    thanks thats it!
