If you had already registered your account at Plesk 360 (formerly known as My Plesk) please use one for login. Otherwise please re-register it using the same email address as your existing Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account.
How to create several mailboxes on Plesk server at once using a single command or a script?
11 comments
    Myhost.ie Support
    The script returns: -bash: ./createmail.sh: /bin/bash^M: bad interpreter: No such file or directory when obtained from wget
    This is probably caused by MSWin line endings?
    Bato Tsydenov
    @Martin
    Thank you for notice. I have updated the article and now working script is attached.
    Bernardo Murillo Montoya
    Hello,
    I created the file mai.txt with the format: "user@domain password"
    but after in the script i see "insertpasswordhere" means every account will be created with the same passwords.
    After research i executed this script:
    for /F "tokens=1,2 delims= " %i in (c:\mail.txt) do plesk bin mail.exe -c %i -passwd %j -mailbox true
    And now the scripts creates the user with the password from file mail.txt.
    if some password is not complex enought will show you the status.
    Alexandr Redikultsev
    Hello @Bernardo Murillo!
    Thank you very much for the input.
    I have updated the article accordingly.
    Stefano Poggioli (Edited )
    Hello,
    everithing seems to be working properly with no errors but...
    passwords are not taken correctly (I set up the txt file as described).
    In fact, if a user tries to use the email address or enter webmail, the password is not recognized.
    If I re-enter the same passwords in plesk email setup, they become correct.
    Why?
    Nikolai Graf-Rüssel
    Is it possible to bulk upload email aliases?
    Denis Bykov
    @Stefano Poggioli
    In case you do it on Windows, I can assume that 'mail.txt' is not well-formed. Try to use the default notepad.exe or notepad++ to edit the input file.
    On Linux, the same may apply if the graphical document editor is used instead of a simple text editor.
    Denis Bykov
    @Nikolai Graf-Rüssel
    Unless I am missing something, the article addresses exactly it.
    Could you clarify your use-case in more detail?
    Nikolai Graf-Rüssel
    This is just for whole mailboxes.
    I just want to add to a mailbox more aliases. Can I do that via bulk with a single script?
    Anton Maslov
    Hi Nikolay,
    Please check documentation and use the same approach combining "for" and command line to do scripts:
    For details on using these options, check the documentation articles: for Linux and for Windows.
    1
    Nikolai Graf-Rüssel
    thanks thats it!
