How to create several mailboxes on Plesk server at once using a single command or a script?
4 comments
    Martin
    The script returns: -bash: ./createmail.sh: /bin/bash^M: bad interpreter: No such file or directory when obtained from wget
    This is probably caused by MSWin line endings?
    Bato Tsydenov
    @Martin
    Thank you for notice. I have updated the article and now working script is attached.
    Bernardo Murillo
    Hello,
    I created the file mai.txt with the format: "user@domain password"
    but after in the script i see "insertpasswordhere" means every account will be created with the same passwords.
    After research i executed this script:
    for /F "tokens=1,2 delims= " %i in (c:\mail.txt) do plesk bin mail.exe -c %i -passwd %j -mailbox true
    And now the scripts creates the user with the password from file mail.txt.
    if some password is not complex enought will show you the status.
    Alexandr Redikultsev
    Hello @Bernardo Murillo!
    Thank you very much for the input.
    I have updated the article accordingly.
