If you had already registered your account at Plesk 360 (formerly known as My Plesk) please use one for login. Otherwise please re-register it using the same email address as your existing Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account.
Unable to add remote git repository with ssh key using Git extension: Could not read from remote repository
7 comments
    George Pittas
    It does not work could you please fix it?
    3
    Tobias Schnittger
    I've been waiting for the fix for several weeks now, a bit annoying. The described workaround did not work for me. What is the situation with the fix?
    2
    Cristiano Masi
    I tried the workaround but I am having the same problem:,
    • Cloning into bare repository '/var/www/vhosts/<site>/git/<repository>.git'...
    • Server at 'github.com' is seen for the first time.
    • Adding its public key to the list of known hosts in '/var/www/vhosts/<site>/.ssh/git_known_hosts'.
    • getaddrinfo github.com: No address associated with hostname
    • Failed to gather public SSH host key for the 'github.com'.
    • Known hosts file '/var/www/vhosts/<site>/.ssh/git_known_hosts' doesn't exist
    • fatal: Could not read from remote repository.
    • Please make sure you have the correct access rights
    • and the repository exists.
    Arvid de Jong
    I have the same problem, but only with subscriotions who's having two FTP accounts
    Mail
    I have the same problem.
    Mail
    When will there be an update here?
    Adrian Finschow (Edited )
    Since no one from Plesk want's to give a temporary answer, I will help.
    I had the same Problem and fixed it that way:
    1. Login with system user of the domain on SSH
    2. Then go into .ssh with cd .ssh
    3. Check with ls if the file git_known_hosts exist
    4. If the file doesn't exist just use touch git_known_hosts and check with ls again if the files exist
    5. If the file now exist and you added your generated SSH-Key to GitHub it should work now!
    At least that was my way to fix the Problem :)
