plesk repair fs fails to check permissions on /var/lib/psa/dumps: ERR [util_exec] proc_close() failed with exit code [1]
4 comments
    Alexandr Tumanov
    @Jürgen, yes, this file is present in MU21.
    The easiest solution will be is upgrading to 17.8
    Christoph Farnleitner
    I'm stuck with v17.5.x since there is no multi server support in v17.8.x. What other workarounds are there that can be applied?
    Bato Tsydenov
    @Christoph Farnleitner
    As a workaround please use the following command:
    plesk sbin fsmng --check-ac /var/lib/psa/dumps --perms 0750 --owner psaadm --group psaadm --filetype directory
    Jürgen Fröhler
    Well under Plesk Onyx 17.5 it seems the workaround get overriden by plesk and the issue returns again
