How to whitelist IP addresses for ModSecurity in Plesk?
6 comments
    Alban Staehli
    Would the below rule to whitelist IP and turn off all rules (meaning modsec is turned off for that particular IP) work as well?
    SecRule REMOTE_ADDR "^203\.0\.113\2$"
    phase:1,nolog,allow,ctl:ruleEngine=Off
    Denis Bykov
    @Alban Staehli
    Starting from ModSecurity 2.7, IDs became mandatory.
    Apart from it, that is also a valid method:
    Marius Melinskas
    Just to expand the query a bit more. two questions are:
    1. a portion of the site is not working correctly, modsecurity (tradeoff setting) logs are empty, site access logs show only a generic 404 status code on the query: Where do I find which modsecurity ruleID is blocking the traffic?
    2. Can I whitelist an IP for all modsec ruleIDs explicitly?
    Thank you in advance for your help on this
    Alisa Kasyanova
    @Marius Melinskas
    1) Check the error log of the domain (/var/www/vhosts/system/example.com/logs/error_log), it should give you some additional information about 404.
    2) Please check https://github.com/SpiderLabs/ModSecurity/wiki/ModSecurity-Frequently-Asked-Questions-%28FAQ%29#ModSecurity_Rules_Language , it describes the method to whitelist IP address.
    Emil Stahl Pedersen
    Modify log to nolog if you don't want to fill the log with "Access allowed (phase 1)." entries.
    Before:
    phase:1,log,allow,ctl:ruleEngine=Off,id:55666
    After:
    phase:1,nolog,allow,ctl:ruleEngine=Off,id:55666
    1
    Ivan Postnikov
    Hello @Emil,
    Thank you for the notice, it may be useful for other Pleskians.
