If you had already registered your account at MyPlesk.com/Plesk360/Platform360 please use one for login. Otherwise please re-register it using the same email address as your existing Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account.
How to whitelist IP addresses for ModSecurity in Plesk?
7 comments
    Alban Staehli
    Would the below rule to whitelist IP and turn off all rules (meaning modsec is turned off for that particular IP) work as well?
    SecRule REMOTE_ADDR "^203\.0\.113\2$"
    phase:1,nolog,allow,ctl:ruleEngine=Off
    Denis Bykov
    @Alban Staehli
    Starting from ModSecurity 2.7, IDs became mandatory.
    Apart from it, that is also a valid method:
    Marius Melinskas
    Just to expand the query a bit more. two questions are:
    1. a portion of the site is not working correctly, modsecurity (tradeoff setting) logs are empty, site access logs show only a generic 404 status code on the query: Where do I find which modsecurity ruleID is blocking the traffic?
    2. Can I whitelist an IP for all modsec ruleIDs explicitly?
    Thank you in advance for your help on this
    Alisa Kasyanova
    @Marius Melinskas
    1) Check the error log of the domain (/var/www/vhosts/system/example.com/logs/error_log), it should give you some additional information about 404.
    2) Please check https://github.com/SpiderLabs/ModSecurity/wiki/ModSecurity-Frequently-Asked-Questions-%28FAQ%29#ModSecurity_Rules_Language , it describes the method to whitelist IP address.
    Emil Stahl Pedersen
    Modify log to nolog if you don't want to fill the log with "Access allowed (phase 1)." entries.
    Before:
    phase:1,log,allow,ctl:ruleEngine=Off,id:55666
    After:
    phase:1,nolog,allow,ctl:ruleEngine=Off,id:55666
    1
    Ivan Postnikov
    Hello @Emil,
    Thank you for the notice, it may be useful for other Pleskians.
    Hussein AbuTaleb
    hi
    is there another way to do this other than SSH?
    thanks
