How to forward messages basing on their content in Horde webmail
5 comments
    Artyom Baranov
    @Agustin Romanos,
    Hi! The instructions in this article are for Horde webmail. I can suggest looking for a Roundcube-related article in our Knowledge Base using the error you face or records from /var/log/maillog
    Pavel Rozental
    Hello @Karl Heinz,
    > "redirect to" option, not available...
    "redirect to" option is available only if dovecot is intalled on the server.
    You can check it at Tools & Settings > Server Components
    You should find "dovecot" here.
    If "courier-imap" is used - install dovecot at Plesk > Tools&Settings > Updates and Upgrades > Add/Remove components. See resolution from https://support.plesk.com/hc/en-us/articles/115004589974 as an example.
    Agustin Romanos
    Hello! I am using roundcube filters like you explain here, but message do not support SRS, SPF is broken.
    I am using "Redirect message to" or "Send message copy to" options.
    Can you help me ?
    Best, Agustin
    Unknown User
    Solved!
    THANKS!
    Unknown User
    Hello
    Version Plesk Onyx v17.8.11_build1708180301.19 os_CentOS 7
    OS CentOS Linux 7.6.1810 (Core)
    Horde 5.2.17
    Any suggestion to get it in my horde?
    TIA!
