A WordPress website hosted in Plesk does not work: Error establishing a database connection
3 comments
    Emilio Plano Fenoglio
    Thanks for the post. However I would like to know the reason that wp-config.php change frequently and automatically in Plesk . In this case I have to reedit the file to recover the functionality of the web page.
    Alexandr Redikultsev
    Hi @Emilio Plano Fenoglio,
    There is no functionality in Plesk to modify wp-config.php by any means, so whatever modified the file does not came from Plesk or WordPress toolkit, however some plugins can do that as far as I know.
    I would recommend to configure audit on the file in order to find out when it is getting changed: https://linux-audit.com/configuring-and-auditing-linux-systems-with-audit-daemon/
    2
    jnasser
    @Alexandr Redikultsev this is so much work to do it for each db each client, im moved from cpanel to plesk, i was hopping to get it easy.
