Plesk for Linux
kb: technical
Error loading module while running PHP script:
CONFIG_TEXT: PHP Warning: Module '<module_name>' already loaded in Unknown on line 0
A PHP Module is enabled several times in one of the php.ini
files.
Connect to the server using SSH
Check the
.ini
files of the PHP handler and find duplicates using the module name from the error:For PHP version provided by OS vendor:
# grep -iR 'module_name' /etc/php/
For PHP X.X version shipped with Plesk, e.g. 7.4:
# grep -iR 'module_name' /opt/plesk/php/X.X/etc/
For custom php.ini file for the domain:
# grep -iR 'module_name' /var/www/vhosts/system/example.com/conf/etc/
Comment or remove the duplicated directive line using some text editor such as Vi.
