How to define PHP limit max_execution_time for a domain in Plesk?
2 comments
    Mario
    How can we change to a higher value? as even 120 in some instances is not enough. i.e. when the client is performing a (heavy) WordPress template import. We would need to be able to temporarily increase this in certain cases.
    Thanks
    Ivan Postnikov
    Hello @Mario,
    Just click at the number and you will be able to specify custom value:
