How to define PHP limit max_execution_time for a domain in Plesk?
5 comments
    Mario
    How can we change to a higher value? as even 120 in some instances is not enough. i.e. when the client is performing a (heavy) WordPress template import. We would need to be able to temporarily increase this in certain cases.
    Thanks
    -1
    Ivan Postnikov
    Hello @Mario,
    Just click at the number and you will be able to specify custom value:
    1
    Guillermo Gorostiaga Buey
    Even changing the versions I can't make changes on the values. How can I fix it?
    1
    Maxim Krasikov
    Hello @Guillermo Gorostiaga Buey,
    Please contact Plesk support for assistance:
    1
    Stefan Pabst (Edited )
    Hey!
    I would like to set the max_execution_time for two php files to 1500. But the rest of the page should still have 300. Is it possible to solve this without allowing the whole subscription a max_execution_time of 1500?
    1
