Plesk Onyx for Linux
Plesk Onyx for Windows
kb: how-to
ABT: Group A
- Plesk Onyx for Linux
- Plesk Onyx for Windows
How to define PHP limit max_execution_time
in Plesk?
- Log into Plesk.
- Navigate to Domains > example.com > PHP Settings
- Select or specify
max_execution_time
in seconds:
- Press the OK button to apply changes.
4 comments
How can we change to a higher value? as even 120 in some instances is not enough. i.e. when the client is performing a (heavy) WordPress template import. We would need to be able to temporarily increase this in certain cases.
Thanks
Hello @Mario,
Just click at the number and you will be able to specify custom value:
Even changing the versions I can't make changes on the values. How can I fix it?
Hello @Guillermo Gorostiaga Buey,
Please contact Plesk support for assistance:
