How to enable Apache PHP module for a domain?
2 comments
    Keith Arnold
    Is there another article on how to Enable mod_php5 as the linked article is not available. I get:
    oops
    You're not authorized to access this page
    Regards
    Keith
    Ivan Postnikov (Edited )
    Hello @Keith!
    Thank you for noticing.
    Indeed, that other article is currently unavailable, it is being reviewed to be more helpful.
    I will post the required steps here but be adviced that this steps are done at your own risk and enabling the Apache handler mod_php is not safe as it is outdated and insecure. Use PHP in FastCGI or FPM mode instead.
    1. In Plesk, go to Tools & Settings > Apache Web Server:
      1.1. Change the MPM mode to Prefork.
      1.2. Click Apply.
      1.3. Enable the 'php5' module.
      1.4. Click OK.
      • Additionally on Debian/Ubuntu-based distributions, connect to a Plesk server via SSH and apply the following commands additionally:
        touch /var/lib/apache2/module/disabled_by_admin/mpm_event
        # touch /var/lib/apache2/module/enabled_by_admin/mpm_prefork
        # touch /var/lib/apache2/module/enabled_by_admin/php5
    2. Then, go to Tools & Settings > PHP Settings. and enable the Apache mod_php handler.
    3. To set the Apache mod_php handler for a domain, go to Domains > example.com > PHP Settings: Select PHP version by OS vendor and run PHP as mod_php.
    Only steps 2 and 3 may be sufficient for Plesk Onyx
