How to add custom directives or custom rule set for ModSecurity via CLI?
In order to add custom directives for "Atomic Basic ModSecurity" follow these steps:
Connect to the server via SSH .
Enable ModSecurity:
# plesk bin server_pref --update-web-app-firewall -waf-rule-engine on
Create a configuration file for custom rules in
/etc/apache2/conf.d
or/etc/httpd/conf.d
directory. As an example:# cd /etc/httpd/conf.d
# wget https://www.atomicorp.com/examples/01_modsecurity.conf -
Put custom rules into the
/etc/httpd/modsecurity.custom.d/99_zzz_custom.conf
file. -
Check Apache configuration:
# httpd -t
Syntax OK -
If test was successful, restart Apache with the following command:
# service httpd restart
For more information visit Official CLI Linux Plesk Documentation .
As an alternative, you can set full custom rule set with following command:
# plesk bin server_pref --update-web-app-firewall -waf-rule-engine on -waf-rule-set custom -waf-archive-path /root/custom_rule_set.conf.tgz
Note: The file custom_rule_set.conf.tgz
should contain only .conf files for usage on ModSecurity custom ruleset.
