Websites hosted in Plesk are loading over HTTP, but do not work over HTTPS:
CONFIG_TEXT: 502 Bad Gateway nginx
CONFIG_TEXT: ERR_CONNECTION_REFUSED
The following error appears at Domains > example.com > Logs or in domain's /var/www/vhosts/system/example.com/logs/proxy_error_log:
CONFIG_TEXT: connect() failed (111: Connection refused) while connecting to upstream, client: 203.0.113.2, server: example.com, request: "GET / HTTP/2.0", upstream: "https://192.0.2.2:7081/", host: "example.com"
The ssl_module
is not included into Apache configuration, as a result Apache is not listening on port 7081 (when nginx is enabled in Tools & Settings > Services Management) or 443 port (when nginx is disabled in Tools & Settings > Services Management):
on CentOS/RHEL-based distributions
# netstat -tunap | grep httpd
tcp 0 0 0.0.0.0:7080 0.0.0.0:* LISTEN 2647/httpd -
on Debian/Ubuntu-based distributions
# netstat -tunap | grep apache
tcp6 0 0 :::7080 :::* LISTEN 763/apache2
Enable Apache ssl_module
Connect to a Plesk server via SSH.
Make sure that the
conf.d
directory is included in Apache configuration:# grep IncludeOptional /etc/httpd/conf/httpd.conf
IncludeOptional conf.d/*.confIf no output is returned or the line has a hash sign "#" at the beginning, open the file
in any text editor (for example, vi editor) and add/uncomment the mentioned line. -
Restore the default
ssl.conf
file:3.1. Download the file for your OS and unzip it:
CentOS/RHEL/CloudLinux 8
# wget https://plesk.zendesk.com/hc/article_attachments/360015629659/ssl_conf_8.zip
# unzip ssl_conf_8.zip -
CentOS/RHEL/CloudLinux 7
# wget https://plesk.zendesk.com/hc/article_attachments/360019724433/ssl_conf_7.zip
# unzip ssl_conf_7.zip -
CentOS/RHEL/CloudLinux 6
# wget https://plesk.zendesk.com/hc/article_attachments/360019019854/ssl_conf_6.zip
# unzip ssl_conf_6.zip
3.2. Rename the original file, if exists:
# mv /etc/httpd/conf.d/ssl.conf /etc/httpd/conf.d/ssl.conf.old
3.3. Put the file in the
conf.d
directory:# mv ssl.conf /etc/httpd/conf.d/
Restart Apache:
# service httpd restart
Verify that Apache is now listening on port 7081:
tcp 0 0 0.0.0.0:7080 0.0.0.0:* LISTEN 17817/httpd
tcp 0 0 0.0.0.0:7081 0.0.0.0:* LISTEN 17817/httpd
- Create two symbolic links:
# ln -s /etc/apache2/mods-available/ssl.conf /etc/apache2/mods-enabled/ssl.conf
# ln -s /etc/apache2/mods-available/ssl.load /etc/apache2/mods-enabled/ssl.load -
Restart Apache:
# service apache2 restart
tcp6 0 0 :::7080:::* LISTEN 2462/apache2
tcp6 0 0 :::7081:::* LISTEN 2462/apache2
2 comments
I have the same issue. Running Centos 7 with clean install of Plesk 17.5.3. However there is no apache2 folder or any apache2.
@Ken, this article is for Debian based systems.
Make sure that mod_ssl package is installed:
# yum install mod_ssl
If not, reinstall it and reconfigure apache:
# yum reinstall mod_ssl -y
# plesk repair web -y
Let me know the result.
