Is it possible to create a mailbox or forwarding for domain alias in Plesk?
3 comments
    Joey Cooper
    This seems to have changed recently as it appears no longer possible to add email alias from another domain to the primary domain.
    For example, I have primarydomain.uk as the primary domain. I then have secondarydomain.co.uk as a domain alias of primarydomain.uk. Mail service is enabled on both. When I go to an email address on primarydomain.uk, and go to "Email Aliases" tab, I can only add email aliases for @primarydomain.uk and no other option.
    Alisa Kasyanova
    @Joey Cooper
    You have an email address mail@primarydomain.uk. Then you set up an alias for primarydomain.uk, for example, secondarydomain.co.uk. If you select the Mail service option, all mail sent to mail@secondarydomain.co.uk will be available at mail@primarydomain.uk.
    So it is not needed to create a mailbox on the alias domain. Mailbox corresponding to primary domain's mailbox is created automatically.
    Sebastian Ayala
    This function is a really really headache. It is not intended for highly scalable multisites..
    1
