How to set up frame forwarding for Apache manually?
Created:
2017-04-25 14:18:42 UTC
Modified:
2017-08-16 17:21:13 UTC
Have more questions?
Submit a request
  • Plesk for Linux
How to set up frame forwarding for a website on Apache web server manually?
Here are possible ways how to do it for example.com website:
  • Add the following code in /var/www/vhosts/example.com/httpdocs/.htaccess file:
    <IfModule proxy_http_module>
            RewriteEngine On
            RewriteCond %{HTTP_HOST} ^(www\.)?example\.com$ [NC]
            RewriteRule ^(.*) http://example2.com/ [P]
    </IfModule>
    Note: proxy_http Apache module should be activated under Tools & Settings > Apache Web Server .
  • Add the following Apache directives in Plesk under Domains > example.com > Apache & nginx Settings :
     RewriteEngine On
     RewriteRule ^(.*)$ http://example2.com/$1 [P]
    </IfModule>
  • Create /var/www/vhosts/example.com/httpdocs/index.html file with the following content:
    <HTML>
    <HEAD>
    <TITLE>example.com</TITLE>
    </HEAD>
    <FRAMESET>
    <FRAME SRC="http://example2.com/" NORESIZE>
    <NOFRAMES>
    Your browser does not support frames.
    </NOFRAMES>
    </FRAMESET>
    </HTML>
