[FIXED BUG] Default documents set to Default cause website error on Plesk Onyx: 403 Forbidden
2 comments
    Larry Seawell
    It didn't work
    Ivan Postnikov
    @Larry
    Hello!
    The described bug was fixed in Plesk 17.8.
    The article was updated.
    Consider upgrading to 17.8.
    In case the issue on your side persists, consider using this article to troubleshoot the issue further or contact Plesk Technical Support.
    -1
