If you had already registered your account at Plesk 360 (formerly known as My Plesk) please use one for login. Otherwise please re-register it using the same email address as your existing Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account.
How to change the default index for all websites on Plesk
10 comments
    Faris Raouf
    This is really helpful. I'd like to make some suggestions please:
    For item 3, users who are not familiar with Event Handler may wonder which priority to use. Maybe it could be suggested that the default priority should be used.
    For item 4, again new users may be confused. I would assume only the root user would have the correct permissions to run the "subscription" command. But if there is a better user to select, maybe you could add an appropriate suggestion?
    Artyom Baranov
    @Faris Hi!
    Thank you for the feedback.
    Its hard to say for sure, how many handlers already exist and recommending to set the default (lowest) priority can lead to incorrect behavior.
    I have updated the article according your recommendation. Thanks again :)
    Steven Craig
    How do you do this for windows plesk?
    Alexander Tsmokalyuk
    @Steven A solution for Windows was added
    -1
    Denis Bykov
    @Albert Stienen
    What exact error do you see?
    Please note that Powershell should be used and not the default Command Prompt.
    Ivan Postnikov (Edited )
    Hello @Albert,
    Thank you for paying our attention.
    The article was reworked.
    According to IIS documentation, there is no way to change the priority of existing file via command line. If it is necessary to change the priority of such a file, it should be configured manually in IIS > hostname > Sites > example.com > Default Documents.
    A new file can be added to the top of the list using the following script:
    plesk bin site -l | % { if ( $ ) { &$env:windir\system32\inetsrv\appcmd.exe set config $ /section:defaultDocument /enabled:true /+files.[value=`'test.php`'] } }
    Wies Tange
    I tried the Linux solution but unfortunately it does not work on a new vhost.
    event: domain created
    priority: lowest
    user: root
    command: /home/admin/index-order.sh
    I put this .sh file on the server itself on the same path.
    But a new domain still has the html index up front insrtead of the php.
    Is there a way to check in any logs if anything at all happened?
    TIA
    Ivan Postnikov
    Hello @Wies,
    Sorry for the late response.
    I've tested the provided Linux solution for new domains and the solution worked fine for me.
    Please, make sure you've followed all the steps as described.
    The script location I used was /root/DefaultDoc.sh.
    Also, I've noticed you've used a non-standard script name was it modified manually?
    Generally, to make sure the script works as expected, start it manually after replacing "${NEW_DOMAIN_NAME}"  with a real domain name.
    Russell H
    Hi Just wondering how to I replace plesk default index page with our own index for all new domain or subdomain? please help if possible
    Ivan Postnikov
    Hello Russell H
    Please, try this article: https://support.plesk.com/hc/en-us/articles/213367389
