How to change the default index for all websites on Plesk
4 comments
    Faris Raouf
    This is really helpful. I'd like to make some suggestions please:
    For item 3, users who are not familiar with Event Handler may wonder which priority to use. Maybe it could be suggested that the default priority should be used.
    For item 4, again new users may be confused. I would assume only the root user would have the correct permissions to run the "subscription" command. But if there is a better user to select, maybe you could add an appropriate suggestion?
    Artyom Baranov
    @Faris Hi!
    Thank you for the feedback.
    Its hard to say for sure, how many handlers already exist and recommending to set the default (lowest) priority can lead to incorrect behavior.
    I have updated the article according your recommendation. Thanks again :)
    Steven Craig
    How do you do this for windows plesk?
    Alexander Tsmokalyuk
    @Steven A solution for Windows was added
