PHP settings for Roundcube get overwritten after upgrade
Created:
2017-04-19 11:53:31 UTC
Modified:
2017-08-16 15:51:43 UTC
Have more questions?
Submit a request
  • Plesk Onyx 17.5 for Linux
Custom PHP settings for Roundcube webmail specified in /etc/psa-webmail/roundcube/php.ini are missing after Plesk upgrade, for example date.timezone .
This issue is caused by Plesk bug #PPPM-6105 and will be fixed in future product updates.
As a workaround:
1. Back up the modified /etc/psa-webmail/roundcube/php.ini file before upgrade:
# cp -p /etc/psa-webmail/roundcube/php.ini /root/php.ini_before_upgrade_rc
2. Restore custom PHP settings after upgrade:
# cp -p /root/php.ini_before_upgrade_rc /etc/psa-webmail/roundcube/php.ini
Additional information
Roundcube shows 500 error if date.timezone is not specified
