How to create a domain/subdomain/alias using different methods in Plesk
5 comments
    Borja Riveiros
    Good Morning,
    I want to create a subdomain on a domain that I have in my plesk and that points to another server. ex:
    My server: www.pepe.com => 151.80.187.25
    New subdomain www.intranet.pepe.com => 5.5.5.5
    Can you help me please? Thank you
    1
    Glenn
    Client has newer version of their application and wants to move some subdomains and aliases to the new app but on a different IP while keep some subdomains/aliases on the old application on the old IP.
    We can use htaccess:
    RewriteCond %{HTTP_HOST} ^tester.abc\.com [NC]
    RewriteRule (.*) https://192.168.10.25/$1 [R=301,L]
    Not sure how good of a solution this is.
    Glenn
    Is there a way to create a domain alias and assign it to a different IP address?
    Julian Bonpland Mignaquy
    Hi Glenn could you specify what is the purpose of assigning a different IP to a domain alias?
    Anton Maslov
    Hi Glenn: domain alias always uses the same IP as a main domain under subscription. Here is what you need to do:
    1. Create new subscription on new IP where you will create subdomains and aliases on this IP.
    2. Now you can forward by any means: using .htaccess using "forwarding" in Plesk UI instead of alias.
