- Plesk for Windows
How to create a domain/subdomain/alias using different methods in Plesk?
Note: Some resellers/customers may not see these options in their control panel due to permission limitations defined in service plan/subscription settings. Visit this KB article for details.
In Power User view:
- Go to Websites & Domains and click Add Domain / Add Subdomain / Add Domain Alias.
Note: To create a domain for a customer/reseller, go to Customers or Resellers > <customer/reseller_name> > Add Domain.
Domain
Go to Domains and click Add Domain.
In this way, creating a domain will also create a new subscription. This domain will be the main domain of this subscription.Go to Subscriptions > example.com and click Add Domain.
In this way, a new domain will be created inside an existing subscription as an additional domain. -
Subdomain
Go to Domains and click Add Subdomain.
Domain Alias
Go to Domains and click Add Domain Alias.
Domain
To create a domain with a new subscription, use the
plesk bin subscription
utility. To learn more about this utility and its options, go to its documentation page - subscription for Linux / subscription.exe for Windows Server.Run the following command to show the help page:
# plesk bin subscription --help
Example
The following command creates the domain example.com and a subscription of the same name for the Plesk customer John Doe whose login is john_doe, associated with the service plan Default Domain, assigned to the IP address 203.0.113.2, with the system user john and the password password:# plesk bin subscription --create example.com -owner john_doe -service-plan "Default Domain" -ip 203.0.113.2 -login john_doe -passwd "password"
To create an additional domain within a subscription, use the
plesk bin site
utility. To learn more about this utility and its options, go to its documentation page - site for Linux / site.exe for Windows Server.Run the following command to show the help page:
# plesk bin site --help
Example
The following command creates the additional domain example.net under the subscription example.com with document root directory /example.net (Full path /var/www/vhosts/example.com/example.net):# plesk bin site --create example.net -webspace-name example.com -www-root /example.net
Subdomain
To create a subdomain, use the
plesk bin subdomain
utility. To learn more about this utility and its options, go to its documentation page - subdomain for Linux / subdomain.exe for Windows Server.Run the following command to show the help page:
# plesk bin subdomain --help
Example
The following command creates the new subdomain subdomain.example.com for the main domain example.com with document root directory /subdomain.example.com (Full path /var/www/vhosts/example.com/subdomain.example.com):# plesk bin subdomain --create sub -domain example.com -www-root /subdomain.example.com
Domain alias
To create a domain alias, use the
plesk bin domalias
utility. To learn more about this utility and its options, go to its documentation page - domalias for Linux / domalias.exe for Windows Server.Run the following command to show the help page:
# plesk bin domalias --help
Example
The following command creates the domain alias example.net for the domain example.com with default settings:# plesk bin domalias --create example.net -domain example.com
Domain
To learn how to create to create domains with a new subscription using Plesk XML API, visit this documentation page:
Example
The following command creates the domain example.com and a subscription of the same name, assigned to the IP address 203.0.113.2, with the system user john and the password password:CONFIG_TEXT: <packet>
<webspace>
<add>
<gen_setup>
<name>sample.com</name>
<ip_address>203.0.113.2</ip_address>
</gen_setup>
<hosting>
<vrt_hst>
<property>
<name>ftp_login</name>
<value>john_doe</value>
</property>
<property>
<name>ftp_password</name>
<value>password</value>
</property>
</vrt_hst>
</hosting>
</add>
</webspace>
</packet>To learn how to create additional domains withing a subscription using Plesk XML API, visit this documentation page:
The following command creates the additional domain example.net under the subscription example.com, id of which is 3, with document root directory /example.net (Full path /var/www/vhosts/example.com/example.net):
<site>
<add>
<gen_setup>
<name>example.org</name>
<webspace-id>3</webspace-id>
</gen_setup>
<hosting>
<vrt_hst>
<property>
<name>www_root</name>
<value>/example.net</value>
</property>
</vrt_hst>
</hosting>
</add>
</site>
</packet> -
Subdomain
To learn how to create subdomains using Plesk XML API, visit this documentation page:
Example
The following command creates the new subdomain subdomain.example.com for the main domain example.com with document root directory /subdomain.example.com (Full path /var/www/vhosts/example.com/subdomain.example.com):CONFIG_TEXT: <packet>
<subdomain>
<add>
<parent>example.com</parent>
<name>subdomain</name>
<property>
<value>/subdomain.example.com</value>
</property>
</add>
</subdomain>
</packet> -
Domain Alias
To learn how to create domain alias using Plesk XML API, visit this documentation page:
Example
The following command creates the domain alias example.net for the domain example.com, id of which is 3, with default settings:CONFIG_TEXT: <packet>
<site-alias>
<create>
<site-id>3</site-id>
<name>example.net</name>
</create>
</site-alias>
</packet>
4 comments
Is there a way to create a domain alias and assign it to a different IP address?
Hi Glenn could you specify what is the purpose of assigning a different IP to a domain alias?
Client has newer version of their application and wants to move some subdomains and aliases to the new app but on a different IP while keep some subdomains/aliases on the old application on the old IP.
We can use htaccess:
RewriteCond %{HTTP_HOST} ^tester.abc\.com [NC]
RewriteRule (.*) https://192.168.10.25/$1 [R=301,L]
Not sure how good of a solution this is.
Hi Glenn: domain alias always uses the same IP as a main domain under subscription. Here is what you need to do:
1. Create new subscription on new IP where you will create subdomains and aliases on this IP.
2. Now you can forward by any means: using .htaccess using "forwarding" in Plesk UI instead of alias.
