Plesk for Linux
kb: how-to
ext: kolab
ABT: Group B
Does Plesk support CalDav and CardDav features?
Yes, starting from Plesk Onyx of 17.5 version, such features are available when the Plesk Premium Email (powered by Kolab) extension is installed.
6 comments
Hello,
Does Plesk support using CalDav & CardDav via Horde?
@Dr. Koontz Hi, As I can see you've created a ticket to us, the answer will be provided there.
Could you also provide the answer here. I am trying to share a calendar via horde but when I add it to Outlook, nothing happens and no error.
I can add a WebDav calendar to Outlook but I it's not editable.
Thanks
G
Hello Glenn
Plesk officially supports CalDAV usage in Plesk Premium email only, so the scenario of setting up CalDAV with Horde was not tested and there are no ready instructions on how to do it.
I can suggest trying to set it up using any found guides (I have found these as an example, you may try to use them: https://help.one.com/hc/en-us/articles/115005586969-How-do-I-sync-the-calendar-with-my-iPhone-using-CalDAV- or https://help.opensrs.com/hc/en-us/articles/204376823-CalDAV-and-CardDAV-Synchronization-with-Hosted-Email-#1).
Without having support for CloudLinux in Plesk Premium email there is currently no "easy" solution for those of us running it.
Hello @Richard Anthony Secor,
You are correct, at the moment CalDav and CardDav features are available only when Plesk Premium Email (Kolab) extension is installed.
At the moment we do not have ETA on when the Plesk Premium Emil will be release on CloudLinux OS.
