Unable to pull updates from Git repository in Plesk: Permission denied: Could not read from remote repository
16 comments
    Zahid Mahmood
    I am experiencing an error when trying to set up a second (or multiple) Git repos on my server. I get the error:
    Public key for the server at 'github.com' is already known in...
    Could these issues be related?
    Jan Černín
    Hello,
    we are experiencing this issue, and the temporary resolution helped, thank you.
    Is there a possiblity to watch over the bug resolution case? I would like to stay updated on the issue, and know when (and if) this get fixed. Thank you.
    Alexandr Tumanov
    @Jan, you can subscribe to the article to stay tuned. Additional information can be found here: https://support.plesk.com/hc/en-us/articles/115002200894-How-to-subscribe-to-Plesk-articles
    Artyom Baranov
    @Zahid Mahmood,
    Hello! Could you please provide us with exact error? What is under "Public key for the server at 'github.com' is already known in" ?
    Unknown User
    I did a copy of the .shh directory.
    But it's using a .ssh/git_known_hosts file from another domain.
    When i delete the git_known_hosts file there it will create a new one(also there)
    Unknown User
    Please, fix this bug!
    Ivan Postnikov
    Hello @Helen,
    The issue from the provided screenshot seems to be different from the one in this article.
    Additionally, I see no articles with a similar issue.
    To find the solution I would suggest to submit a support request.
    Unknown User
    If anyone from reg.ru is trying to work the same problem as me, please, read support answer carefully, it helped me:
    Здравствуйте! Насколько мы видим, вы указали в качестве удаленного Git репозитория команду git: git clone git@bitbucket.org:username/***.git Адрес репозитория имеет следующий вид: git@bitbucket.org:username/***.git Однако, указанный вами адрес репозитория на данный момент не существует. Для решения проблемы вам необходимо указать адрес существующего репозитория, после чего скопировать публичный ключ в ваш репозиторий bitbucket. Подробнее в официальной инструкции - https://docs.plesk.com/ru-RU/onyx/administrator-guide/website-management/git-support/using-remote-git-hosting.75848/ Как добавить публичные ключи на BitBucket - https://www.youtube.com/watch?v=-ElU6WhNLn4 Интерактивный курс по использованию Git - https://githowto.com/ru
    Вы уже оценили ответ
    Ivan Postnikov
    @Helen, thanks for sharing.
    1
    Muhammad Nadir Abbas
    Thank You Very Much, That took a big burden off of me. <3
    Martijn
    Hi Ivan Postnikov, we have something that looks the same as Zahid's problem. I don't see any follow up on that.
    To our knowledge we didn't change anything in Github settings, or the server. And this morning it worked fine. And has worked fine for the last couple of months.
    We have 2 connected github projects, both on different subdomains of the same main domain. We use the SSH way to pull the updates. and a webhook for the automatic pull after pushed to master.
    As said, it worked this morning until I noticed on one of the projects a minor change wasn't showing up on the site after I pushed it. At this point I manually pressed the button in the plesk panel to pull updates. This worked once or twice.
    Then we got the following error: Public key for the server at 'github.com' is already known in '/var/www/vhosts/maindomain.nl/.ssh/git_known_hosts'. error: Ref refs/heads/master is at c034a*** but expected 9c105**** From github.com:****/*** ! 9c105d9..c034abf master -> master (unable to update local ref)
    Ivan Postnikov
    Hello @Martjin,
    Our Support Department has met such issue once. However, the exact root cause wasn't found. In that case,the solution was to remove the git repository and to re-add the git repository. Probably, this was a misconfiguration on the git side.
    If this won't resolve the issue, consider submitting a request for Plesk Support, as the deeper investigation will be required.
    Martijn
    Hello Ivan Postnikov,
    The issue was caused by a issue on the Github.com side.
    https://www.githubstatus.com/incidents/42hkbtl63nmn
    I still had to remove the repository in question and re-add it to get rid of the error. But prior to that, the other project was already functioning ok again, responding to the webhook etc.
    It all seems to be working correctly again at the moment.
    Thanks for your input.
    Ivan Postnikov
    Hello @Martjin,
    Thank you for sharing this information, it may be useful for other Pleskians!
    Gregor (Edited )
    The temporary solution provided did not work in my case. I did:
    • add the ssh key to my GitHub settings
    • copy the contents of /var/www/vhosts/example.com/.ssh to /var/www/vhosts/example.com/sub.example.com/.ssh
    Still getting this error when trying to add a repository via the Plesk interface:
    Cloning into bare repository '/var/www/vhosts/example.com/git/my-repo.git'...
    Public key for the server at 'github.com' is already known in '/var/www/vhosts/example.com/.ssh/git_known_hosts'.
    Permission denied (publickey).
    fatal: Could not read from remote repository.
    Please make sure you have the correct access rights
    and the repository exists.
    UPDATE:
    Figured it out myself: I realized I have configured a passphrase when generating my ssh keys. Maybe this prevented Plesk from cloning from GitHub. It works now! :)
    Ivan Postnikov
    Hello Gregor,
    Thank you for the update, glad to hear it's sorted out
    1
