- Plesk Onyx for Linux
Roundcube Webmail failed to open with 500 error in the browser.
The following error appears in
/var/log/plesk-roundcube/errors
:PHP Fatal error: Class 'PDO' not found in /usr/share/psa-roundcube/program/lib/Roundcube/rcube_db_mysql.php on line 144
Listing of system php modules does not show
pdo_sqlite
module:# php -m | grep -i pdo
There is a custom value for
extension_dir
directive:# php -i | grep extension_dir
extension_dir => ./ => ./
System PHP misconfiguration.
Note: This article may require additional administrative knowledge to apply. If any help required, contact the server’s administrator or hosting support.
Log in to Plesk server via SSH
Comment out
extension_dir
directive in the/etc/psa-webmail/roundcube/php.ini
and/etc/php.ini
files, e.g.:# grep extension /etc/psa-webmail/roundcube/php.ini
;extension_dir = "./"So, the value for
extension_dir
directive should look as follows:# php -i | grep extension_dir
extension_dir => /usr/lib64/php/modules => /usr/lib64/php/modules -
Turn on the
pdo, pdo_mysql and pdo_sqlite
extensions under Home > Tools & Settings > PHP Settings > %php_version% by OS vendor FastCGI application -
Make sure that modules were activated using the following command:
# php -m | grep -i pdo PDO pdo_mysql pdo_sqlite
