Starting on October 19, 2021, we will enable single-sign-on for our Plesk Support Center to provide a seamless login/account experience. This implies that you’ll be able to use a single account across any of our web-facing properties.
To be prepared for this change and to avoid the need to register during your next ticket submission after the change, we encourage you to create an account here before October 19 using the same email address as your current Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account. You will continue to use ZenDesk authentication until we switch over to single-sign-on on October 19th.
 How to enable DKIM in Plesk?
11 comments
    Andrey Zelenchuk
    Plesk 17.8 - 17.0 for Windows do not have the Verify incoming mail option...
    Andrey Zelenchuk (Edited )
    I am not authorized to access the "How to enable DKIM signing for all domains on Plesk for Windows server?" page which is referenced in this article 3 times...
    Anzhelika Khapaknysh (Edited )
    Hi @Andrey Zelenchuk,
    You're right - Verify incoming mail option is available on Linux servers only.
    Regarding the "How to enable DKIM signing for all domains on Plesk for Windows server?" article - I've fixed the access to it. Please check it.
    Pieter van Kampen
    Hi
    I use MailEnable  Standard 10.12 with Plesk 17.8.11, but there is no DKIM Span Protection Section in Plesk > Tools & Settings > Mail Server Settings
    Should i do something to get that?
    Alexandr Zubtsovsky
    @Pieter van Kampen
    Hi!
    Please try the following:
    1. Log into Plesk
    2. Go to Tools & Settings > Server Components and click "Refresh".
    If this does not help, please submit a ticket regarding this using these instructions.
    Gonzalo Besoain
    DKIM: How to add extra signed headers?
    According with RFC 8058 "Signaling One-Click Functionality for List Email Headers" (https://tools.ietf.org/html/rfc8058) in order to use the header "List-Unsubscribe" this must be included on "h" tag of DKIM sign, nowadays only "From:To:Subject;" are included on DKIM-Signature.
    So, how can I add this extra header on the DKIM signature?
    Nick Plekhov
    Hello, @Gonzalo Besoain
    It is possible to modify the DKIM record in Plesk > Domains > example.com > DNS Settings
    If you click on default._domainkey.example.com record you will be able to specify any tags including h= in the TXT record field.
    Please mind that DKIM should be enabled globally for the whole server and for the domain example.com otherwise, this TXT record will not exist.
    1
    Gonzalo Besoain
    Hi @Nick Plekhov
    I understand that on DKIM DNS record the tag "h" is used to indicate hash algorithm.
    RFC 8058 refers to add the "h" tag on the DKIM-Signature that is generated for each email sent.. by Plesk postfix in my case.
    For example:
    DKIM-Signature: v=1; a=rsa-sha256; c=relaxed/relaxed; s=dk2016; d=somedomain.com;
      h=List-Unsubscribe:From:To:Subject;...
    Alexandr Nikolaenko
    Hello Gonzalo Besoain,
    Thank you for clarification.
    Currently, Plesk does not provide an option to tune "DKIM-Signature" header.
    Please submit a feature suggestion on our Plesk UserVoice portal and it will be considered for implementation in future releases.
    Kea
    Is there any way to make it enabled by default for individual domains?
    1
    Ivan Kamnev
    Hello @Kea,
    It is not possible to set DKIM enabled by default for the specific domain.
    After enabling the DKIM in Tools & Settings > Mail Server Settings > DKIM spam protection it is required manually to enable the Use DKIM spam protection system to sign outgoing email messages option in Domains > example.com > Mail Settings.
