How to enable DKIM spam protection for outgoing emails of particular domain in Plesk
4 comments
    Iain
    What is not mentioned is how you obtain the public key to publish in DNS. The article does mention; "if external DNS provider is used, contact your DNS owner in order to add DKIM record" ... but it would help to know what the public key is to add :-)
    Ivan Postnikov
    Hello Iain
    This instruction contains an answer to your question.
    Iain
    Thanks Ivan Postnikov. Indeed I found and used that article, but it would be worth including at least a link this this in the main article here as you can't enable DKIM without publishing the selector key and so it really needs to be a part of the solution :-)
    Ivan Postnikov
    Hello Iain
    Thank you for clarification.
    I've added the corresponding link.
    1
