Starting on October 19, 2021, we will enable single-sign-on for our Plesk Support Center to provide a seamless login/account experience. This implies that you’ll be able to use a single account across any of our web-facing properties.
To be prepared for this change and to avoid the need to register during your next ticket submission after the change, we encourage you to create an account here before October 19 using the same email address as your current Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account. You will continue to use ZenDesk authentication until we switch over to single-sign-on on October 19th.
How to check the Plesk Daily Maintenance Task execution time?
2 comments
    Bob B
    Hello,
    The Answer for CentOS/RedHat may need an update.  On CentOS 7, I believe, the cron.daily tasks are scheduled in "/etc/anacrontab".
    Best Regards,
    Bob
    1
    Maxim Krasikov (Edited )
    Hello @Bob B!
    Please let me clarify that Anacron service may be installed or not in initilal Centos/RedHat OS.
    The initial file for running tasks is /etc/cron.d/dailyjobs.
    This file contains the following lines:
    23 3 * * * root [ ! -f /etc/cron.hourly/0anacron ] && run-parts /etc/cron.daily
    The script checks if Anacron file /etc/cron.hourly/0anacron persists. If the file is missing, /etc/cron.daily runs.
