How to set up VPN connection using Plesk VPN extension?
7 comments
    Daria Gavrilova
    Hello @Jan,
    Thank you for your input.
    The article was modified.
    Jan Bludau
    make a cross reference to this article this solves my problems...
    https://support.plesk.com/hc/en-us/articles/115001577713?page=1#comment_360001839794
    Bato Tsydenov
    @Svein A. Berg
    I would recommend you contact OpenVPN support:
    https://openvpn.net/
    They are experts in their product and can assist you with installing TAP driver.
    Ivan Postnikov
    Hello @Lucian,
    That's correct. Due to low popularity, the development of this extension was stopped.
    Check this article for more information: https://support.plesk.com/hc/en-us/articles/360023860913-Which-are-the-deprecated-functionalities-in-Plesk-Obsidian-18-
    Lucian Cesarean
    Hello, where is this extension in Obsidian ? A search yields just cloudplan, which I don't really want. Has it been slashed in Obsidian ? Had I known, I would not have upgraded. Thanks
    Lucian Cesarean
    Hello, hi OK I understand about the development, but why has the extension been removed all together from the catalog ? I had to install the openvpn access server and complicate myself with that solution. Anyways, I'm kinda disappointed. Again, had I known, I wouldn't have updated to Obsidian, now it is too late. Cheers
    Unknown User
    I am running Windows 10, and I get the message "tapinstall failed." when running the Install TAP device.bat (run as Administrator). I've removed the echo off line to see the message. Any idea what needs to be done to make this work?
