How to set up VPN connection using Plesk VPN extension?
2 comments
    Unknown User
    I am running Windows 10, and I get the message "tapinstall failed." when running the Install TAP device.bat (run as Administrator). I've removed the echo off line to see the message. Any idea what needs to be done to make this work?
    Bato Tsydenov
    @Svein A. Berg
    I would recommend you contact OpenVPN support:
    https://openvpn.net/
    They are experts in their product and can assist you with installing TAP driver.
