- Plesk for Windows
- Plesk is not accessible:
PLESK_INFO: ERROR: Zend_Db_Adapter_Exception: SQLSTATE[HY000] [2002] No connection could be made because the target machine actively refused it.
Additionally, an exception has occurred while trying to report this error: Zend_Exception
No entry is registered for key & #039 ;translate& #039 ; (Abstract.php:144) - "bind-address" parameter value in
%plesk_dir%MySQL\my.ini
differs from the 127.0.0.1:CONFIG_TEXT: bind-address=203.0.113.2
Incorrect IP address binding in Plesk SQL Server configuration. Therefore, Plesk fails to connect to SQL Server service on address 127.0.0.1.
Note: if you don't have administrative access to Plesk server via RDP, contact your hosting provider regarding the issue
Login to the server over RDP and remove "bind-address" directive from %plesk_dir%MySQL\my.ini.
