If you had already registered your account at MyPlesk.com/Plesk360/Platform360 please use one for login. Otherwise please re-register it using the same email address as your existing Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account.
Domains on PHP-FPM do not work with error 503 after changing virtual hosts location: the prefix '/var/www/vhosts/system/example.com' does not exist or is not a directory
2 comments
    Christian B.
    Hi George,
    in my case i can't update my plesk version or to a newer PHP version. So i returned to 7.0 and deleted 7.3 and 7.4 to be sure. No I see in the logs while executing systemctl status php7.0-fpm.service following error messages.
    The prefix shows to an old domain which has already be removed time ago. In one of my domain i select the 7.0 and apply, and then i used your update command but the prefix doesn't change. Any tipps?
    ● php7.0-fpm.service - The PHP 7.0 FastCGI Process Manager
    Loaded: loaded (/lib/systemd/system/php7.0-fpm.service; enabled; vendor preset: enabled)
    Drop-In: /lib/systemd/system/php7.0-fpm.service.d
    └─limit_nofile.conf
    Active: failed (Result: exit-code) since Do 2020-08-20 14:29:38 CEST; 1h 4min ago
    Main PID: 10885 (code=exited, status=78)
    Aug 20 14:29:37 hostname systemd[1]: Starting The PHP 7.0 FastCGI Process Manager...
    Aug 20 14:29:38 hostname php-fpm7.0[10885]: [20-Aug-2020 14:29:38] ERROR: [pool deleteddomain] the prefix '/var/www/vhosts/system/deleteddomain' does not exist or is not a directory
    Aug 20 14:29:38 hostname php-fpm7.0[10885]: [20-Aug-2020 14:29:38] ERROR: failed to post process the configuration
    Aug 20 14:29:38 hostname php-fpm7.0[10885]: [20-Aug-2020 14:29:38] ERROR: FPM initialization failed
    Aug 20 14:29:38 hostname systemd[1]: php7.0-fpm.service: Main process exited, code=exited, status=78/n/a
    Aug 20 14:29:38 hostname systemd[1]: Failed to start The PHP 7.0 FastCGI Process Manager.
    Aug 20 14:29:38 hostname systemd[1]: php7.0-fpm.service: Unit entered failed state.
    Aug 20 14:29:38 hostname systemd[1]: php7.0-fpm.service: Failed with result 'exit-code'.
    Ivan Postnikov
    Hello Christian B.
    Please, follow the instructions from this article: https://support.plesk.com/hc/en-us/articles/213409669
    The reason for such behavior is some configuration left after domain removal.
